4000rpm @ 60mph
Old 06-04-2011 | 09:38 AM
Default 4000rpm @ 60mph
Im kind of new to things and i didnt know if this was good or not.. 4000rpm @ 60 mph with a 24p x 14 and 1.50 drive, with the trim all the way down. Ive heard of prop slip and not sure how much this one is slipping. thanks for the help
Teddysfever is offline
Old 06-04-2011 | 09:52 AM
What motor? And what RPM speed do you run at nuetral and positive trim?
GTOFFSHORE is offline
Old 06-04-2011 | 10:09 AM
454mag and havent had the chance to try playin with the trim, i was water testing in a small river since are lake is trashed
Old 06-04-2011 | 02:57 PM
Havasu Hangin's Avatar
Is that GPS?
Havasu Hangin is offline
Old 06-04-2011 | 03:03 PM
That sounds a bit of an optimistic speed at 4000 rpm with a 24p prop. Is that speed using a gps? That's what I'm doing with 30p props.
ActiveFun is offline
Old 06-04-2011 | 03:35 PM
I got 1% slip...lol. Better verify the speed or the tach.
Old 06-04-2011 | 03:36 PM
Default Fixx
ok so your new to this..in order to achieve the proper rpm's and correct top speed you will need to trim the boat out more..your best bet is to go to the fountain owners part of this forum and ask''what is the perfect trim to achieve the correct speed,,with tabs,with out tabs ..
FIXX is offline
