prop comparison >
prop comparison
prop comparison
Old 06-05-2011 | 10:51 AM
Default prop comparison
Without getting into all the details....just shoot from the hip and give me your opinion. Stock Bravo 1 four blade vs. stock Hydromotive four blade...which is faster ?
tinman565 is offline
Old 06-09-2011 | 08:29 AM
I have a friend who turns a 28 pitch bravo 1 with a single 502 mpi and runs 78 consistently in his Superboat.
jctexas07 is offline
Old 06-09-2011 | 09:48 AM
Thanks...but I was looking for guys who have run both.
Old 06-09-2011 | 12:05 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Each application can be different.
Hydro Q4 has more transom lift than the B1.
Multy stepped bottoms may see 1-2 mph more with the Q4. Straight V's and single steps or any hull needing more transom leverage or bow lift will be faster with the B1.
Labbing is more effective on the B1.
Brett
[email protected]
bbladesprops is offline
Old 06-09-2011 | 02:02 PM
Thanks Brett.
Old 06-10-2011 | 07:22 PM
97FASTech's Avatar
Veteran: Army
Default Good Info
Thanks Tinman, good thread. I was thinking of going to a Bravo 1 26 pitch on my 271 Fastech single step. It currently has a 24 pitch Q4. With the Q4 and a 1/2 tank of gas I could run 73 non gps. This was before I blew a head gasket end of April. Bravo 1 looks to be a solid choice.
97FASTech is offline
Old 06-14-2011 | 02:12 PM
Brett
That's what I see in my 280 Velocity, but midrange and on plane is better with the B1.
ThisIsLivin is offline
Old 06-22-2011 | 10:08 PM
What do run now on twins with your current setup...?
Old 06-23-2011 | 05:37 AM
26P B1's
Old 06-23-2011 | 08:21 AM
Ted G's Avatar
B1's tend to actually have a little less pitch than they are marked for. Many times a Hydro will not turn as many RPMS as a Bravo because they have more true pitch. But if you can turn your B1s up to rev limit then the Hydros might give you a little more speed.
www.cbpba.com
Ted G is offline
