Keeps Throwing belt...
I'm having some issues with my accessory belt staying on. I have a merc 502 efi mag. I have a m3 on the motor therefor it has the aftermarket serp acc. system. Everything seems to be lined up just fine. All pulleys spin freely. I do have a bit of in and out motion on my powersteering pulley. But only when the belt is off. But its not a lot and the one on my camaro has about the same in out motion and i think its normal. It's only throwing it under load above 4k and or if i'm about 3,000 rpms and make sharp turn. Everything at idle looks and seems to be okay. The belt on there originally was a bit loose. I went to a tighter fit belt same problem. Went back to loose fit same issue. It first started when the end of last year i took a sharp turn. Please help with any ideas.
Thats my guess too. I'm going to make sure that everything is aligned with a straight edge. But either way. Replacing the pump will be preventative maintanance.
Does the serp system have an automatic belt tensioner? If so, that would be the first component I checked. I would also wonder if the belt is routed the correct way? If you can get ahold of a diagram for the aftermarket set up and double check yourself that might save a bunch of headache. Good luck!
I have the same setup..not yet run though..but I found when they installed the set up they did not have the p/s pulley pressed back on the shaft far enough..was at least 3/8 out, could see it if veiwed from the side...now engine was out when I found it and I had the the tool to press the rest of the way on, now lines up fine...but you should not have any movement in the pump...Rob
Rob, i thought the same thing. I am a store manager of a O'Reilly auto parts store. I took about thirty pumps off my shelf and pulled on the shaft. They all seemed to move in and out a slight bit. I mean we are talking about 1/8th to 1/16th inch if that. But maybe it has loosened up a bit and needs cranked on more. You might be right there. I'm going to get up here in a bit and go work on it. I'm surely going to find out what it is and let you all know. Because time after time people post problems but don't bother posting back what the issue was so other people can know. Because you never know... It might help someone in the near future.
Ron
Ron
also, if you need to replace the pump just pull one from your inventory, that looks the same, change the pressure relief valve and spring(under nut where pressure line attaches) over from yours and you will be good to go..
Ron
