ProCharger FYI on tight belts >
Old 06-10-2011 | 07:34 AM
Default ProCharger FYI on tight belts
Just a fyi, I bought a used 26' daytona with a low hour 540 procharged motor, Of course when i get her home, I did all the maintanance, new fluids belt etc. I could never get more than 5 LBS boost or more than 4800 rpm. 95 mph. Thought it had to big of prop. I had the belt on the blower as tight as any fan belt. I go and buy a new merc lab bravo 1 30p,"down from the BBlades 32" at the same time the procharger tech tells me to make my belt really tight. So I go testing to find now I can pull this 30p to 5600 rpm and bounce off the limiter. I put the 32 back on run to 5400 rpm at 8 lbs of boost, 112 mph. a $1100 lesson. Anybody looking for a new labbed 30p?
zx14 is offline
Old 06-10-2011 | 07:44 AM
You know what they say about "boats". Break Out Another Thousand. Lol Enjoy your new boat. B
bulletbob is offline
Old 06-10-2011 | 08:32 PM
How bigga hit ya willing to take?
pachanga is offline
Old 06-10-2011 | 08:44 PM
zx14 Very interesting......Glad you shared that info, It hit home with me.
pacalim1965@yaho is offline
Old 06-10-2011 | 09:26 PM
articfriends's Avatar
8 rib or 12 rib? I went thru this 8 years ago and then switched from 8 rib to 12 rib drive, IMHO the m-3 should NOT even be sold with 8 rib drive system as it has to be rubber band tight to slow the slipping down when running any upper pulley in the 4" or smaller range, Smitty
articfriends is offline
Old 06-11-2011 | 09:29 AM
I am in a similar "boat"......I am really not sure how tight the belt should be? How do you measure how tight it is?
I have a M-1SC with the 8 rib running 5lbs and really not sure if I have the belt adjusted correctly, I am not throwing belts but not sure if I am getting top performance out of it...?
FogduckerIII is offline
