fuel pump wiring
Old 05-31-2002 | 05:04 PM
Default fuel pump wiring
Need help from all you experts on how to wire an electric fuel pump to operate on my oil pressure sending unit.I use VDO guages with the VDO senders.Thanks Fish
fishead is offline
Old 05-31-2002 | 06:24 PM
??????? why would you want to run a fuel pump off a oil preasure switch? either run a switch with a breaker, or a hot from the ignition switch and ground the pump
GOFSTCAT is offline
Old 05-31-2002 | 07:19 PM
Havasu Hangin's Avatar
Arrow
If you lose oil pressure...it kills the engine.
Do you have a switch already? I plumbed mine off a "T" fitting, so I use the same area for both the gauge sending unit and the switch.
Havasu Hangin is offline
Old 05-31-2002 | 09:14 PM
i see now , learn somthing new everyday thanks.
GOFSTCAT is offline
BillR
11
07-29-2022 06:31 AM
freeman1
3
05-10-2003 02:22 PM
fishead
1
05-31-2002 05:44 PM
fishead
02-15-2002 05:50 PM
