Trim tab starting height? >
Old 06-16-2011 | 11:28 AM
Default Trim tab starting height?
30' Power Quest. twin 496-mag HO's, Lenco 16" single actuator tabs. The manufacturer says to position the tab so that the trailing edge of the tab is 1" above the straight edge line drawn from the bottom of the boat. From the factory mine is about 3" I takes about half of the total extension to get to that 1" Is there a reason they are set that high? I can choose a different hole and lower them??
miwettig is offline
Old 06-16-2011 | 11:59 AM
I've always been told 3/4" to and 1".. 3" seems way to high.
endeavour32 is offline
Old 06-16-2011 | 02:50 PM
I will look and take a picture of mine today..
boatnt is offline
Old 06-16-2011 | 03:14 PM
Thanks...mine is in the middle hole.
miwettig is offline
Old 06-18-2011 | 07:50 AM
Yep ,,,same as mine...maybe its time to move it one hole closer.
boatnt is offline
Old 06-18-2011 | 07:54 PM
I moved mine Sat. and noticed improvement. Before I had to go too half tab to see and benefit. Cut thru the chop better and when I needed to compensate for the wind it was just a touch!
miwettig is offline
