water coming in WTF!! >
Old 06-20-2011 | 06:50 AM
Default water coming in WTF!!
I have a substancial amount of water coming in the boat. I was out yesterday and have to turn the bilge on like every hour or two and its a steady stream of water for like 30sec-min. Its a good amount of water. After further inspection yesterday it looks like the water is coming in above the coupler at what looks to be the steering or the shift linkage. Is there some sort of boot or seal there.
nards444 is offline
Old 06-20-2011 | 06:51 AM
What drive setup? Yes, there should be a boot there...
teamsynergy is offline
Old 06-20-2011 | 07:01 AM
twin bravos 1. Like I said ther eis the hole with the coupler or drive shaft then above is like a square whole where what looks like steering or shifting. I would like to say its probably coming in at a couple gallons an hour
nards444 is offline
Old 06-20-2011 | 07:06 AM
obnoxus's Avatar
Charter Member #1171
bellows or steer shaft seal
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 06-20-2011 | 07:11 AM
After looking at at part fiche its it could be upper bellows. If its coming in here should I get new drive fluid as well
nards444 is offline
Old 06-20-2011 | 07:28 AM
seafordguy's Avatar
My guess is swivel shaft seal (steer seal like Obnoxus said)
look up jrmarine.com for more pictures/info. he has a method to fix it but i would just yank the engines and fix it the right way....
seafordguy is offline
Old 06-20-2011 | 07:29 AM
seafordguy's Avatar
water in the bellows wont affect the fluid unless you also have an input seal leaking.
if the leak is above the drive shaft it isnt that bellow...
Old 06-20-2011 | 07:32 AM
ok thanks I didnt think so. From what I could see its coming in above that, some it was dripping down into the coupler area though so Just wondering if enough water could have drained down into the drive somehow
nards444 is offline
Old 06-20-2011 | 07:41 AM
Could be, But really hope and dont wanna yank the engines at this point.
nards444 is offline
Old 06-20-2011 | 07:46 AM
seafordguy's Avatar
well - like I said, JRmarine.com offers an entire kit to fix it from the outside without pulling the engines.
For those of us that have been down the engine removal path before - I just think it is quicker.
