Trailering my 302 boss
Why wouldn't it be? I don't know if you are questioning the boat on the trailer, the overall weight of the package, or the fact that the truck is lifted. As long as the trailer covers the weight of the boat and trailer that shouldn't be an issue. There are plenty of people pulling trailers that exceed the overall weight of the truck towing capacity but as long as your weighted tags are high enough and you don't get into a wreck shouldn't be a problem. The lifted truck part depends on how high its lifted. If its only 4-8 inches shouldn't be a problem but you will need to pay attention in turns as my lifted F250 will kinda role on the side walls of my 36" tall tires. Not an issue once you realize this and you know it will roll a little its just uneasy at first. If your truck is much higher you start putting more stresses on hitches and the center of gravity can affect you. You can pull it you just have to use common sense and you might not be able to pull it as fast as you want.
