496  make loud tone when you trun key >
Old 06-24-2011 | 12:47 AM
Default 496 make loud tone when you trun key
my 496 makes lout constant tone when i turn the key? it beeps once then go's solided even if you dont start eingine? any help I seen the list but this dont make since engines not running?
pagerboy is offline
Old 06-24-2011 | 05:58 AM
lake speed's Avatar
does it go away when you start the motor? if so its most likely a low oil psi alarm.
lake speed is offline
Old 06-24-2011 | 10:13 AM
nope! if ya start the engine it still does it! all fluids are full.
pagerboy is offline
Old 06-24-2011 | 12:27 PM
A scan will tell you what the beep is for. Sorry I don't know that it would be if all the fluids are up.
Darrell.
DMOORE is offline
Old 06-24-2011 | 01:10 PM
low battery voltage
TWIN-SPINS is offline
Old 06-24-2011 | 08:12 PM
well I didn't get a chance to charge it beffore we went out, but it starts, but when it gets to 1500 rpm the motor starts missing really bad and continues to miss even when you let off the throttle. If you shut off the motor and restart it dont miss? got it on the charger gona see if its batteries!
pagerboy is offline
Old 06-26-2011 | 12:12 PM
sometimes it runs good for about 3o sec then it go's to running like crap untill you turn it off and back on
pagerboy is offline
Old 06-26-2011 | 02:18 PM
both batterys are charged! I swaped ecm's still does it? anybody?
pagerboy is offline
Old 06-26-2011 | 09:55 PM
so what sensor is telling the computer a bad value before the motor is even started? fuel pressure mabey?
pagerboy is offline
