carb jetting
buddy just built pair of 575 hp 502 on dyno with stock holley 800 carbs what woulkd be a good jetting set up was thinking 88 and 92 wants to be fat not lean of course and he is running 5300 rpms with timing at 38. What do you think.
problem found. valve guides were to tight.
502's 850 holley's, 580 hp @ 5400 rpm 610 ft lbs trq. 84 and 90 in the carbs now . 86 and 92 on the dyno. we are putting them back in. at 36 on the timming. thanks for the help guys.
not even with 116 octane i would do that !
