Gas gauge way off
I have a 38 Fountain. I just topped it off completely with gas. My gauges both read the same at a little over half. Are these gauges adjustable? They are Gaffrig. Or do I have a sending unit problem? I heard Fountain is notorious for gauge innacurracy
They are adjustable....check the round covers on the floor near the front seat under the carpet. You will find the fuel sending units. Their are 2 tiny screws that are the level adjusments for the gauge.
Thanks. I thought they were adjustable. I'll give that a try. This is why this forum is so awesome
They have a full and empty adjustment so you're gonna have to fill it up adjust and then pull the sender out of the tank and adjust empty. With the boat in the water for accuracy! The smartcraft fuel used is way better and its a plug and play deal. Fountains usually read full all day and once the start to drop pay attention because if it says half you will drop to empty real quick
Theres several threads about gas gauges in the Fountain forum......I'll save you the time....they suck!
In the end we all agreed.....at half you better start looking for a gas station....at a quarter you better be in sight of the gas station because once that needle touches "E" your done....
