gimbal bearing, water ingestion? >
Old 06-30-2011 | 09:10 AM
Default gimbal bearing, water ingestion?
So bought a rebuitl b1 was going to install & noticed water/rust & I'm guessing bearing will be toast soon. Will replace bearing and a set of u joint bellows.....anything else to check for? How/where would water get in there? By replacing the bellows should that be it?
paintman is offline
Old 07-01-2011 | 09:40 AM
I would check shift cable boot for cracks, tears.
pacalim1965@yaho is offline
Old 07-01-2011 | 09:58 AM
Ted G's Avatar
Do the bellows and the shift cable boot while it's apart and you should be good to go.
www.cbpba.com
Ted G is offline
Old 07-02-2011 | 06:21 AM
thanks guys, will do
paintman is offline
