Gen VI Mag piston rings?
I am re-ringing a 1996 454 Magnum MPI and the rings I bought don't fit on the oil ring side. I looked on here and found a few posts but I want to be sure before I buy another set of rings. What rings have the low tension oil rings needed? I am still using the standard bore too.
Sean,
They might be a metric ring setup. They are not low tension, but have a shallow oil ring groove. Probably Hastings 2M4718 Your machine shop should be able to measure them for you and probably can get you the rings as cheap as anyone else.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
