power steering fluid or ATF in stock Merc PS? >
Old 07-08-2011 | 06:03 PM
Default power steering fluid or ATF in stock Merc PS?
Quick question - should I use a specific type of power steering fluid in a stock Merc PS system, or is ATF OK? If ATF, what type - Type F, Dextron, Mercon, etc.?
Thanks!
Budman II is offline
Old 07-08-2011 | 06:43 PM
I have always used trans fluid
jeffswav is offline
Old 07-08-2011 | 07:48 PM
Type F, Mercon, Dextron? Doesn't matter?
Thanks.
Old 07-08-2011 | 09:15 PM
Smitty's Avatar
Use the Dexron/Mercon blend and you will be fine.
Smitty is offline
Old 07-08-2011 | 10:23 PM
Its all universal now
jeffswav is offline
Old 07-09-2011 | 01:09 PM
Rookie's Avatar
Thanks!
Why not just use power steering fluid? I had ATF in mine when the line blew a pin hole leak in it and I had Red ATF everywhere. It made a mess. That Red dye is a mother to clean. A quart of PS fluid at Autozone is the same price.
Rookie is offline
Old 07-09-2011 | 05:48 PM
I just put valvoline synthetic P/S fluid in mine and it has never worked so good, and as the other guy said, this stuff is clear. You can see the mess
45SS is offline
Old 07-09-2011 | 07:59 PM
Thanks!
my book for my 1990 says dexron or dexronII thats what i put back in and all seems good
gsxr1216 is offline
Old 07-09-2011 | 10:20 PM
Ya, and a quart of power steering fluid at the marina when you are out on the lake and it is 100 degrees and your boat dont want to steer is $12.00
fireguy is offline
