Boat Idles Weird?
Old 07-11-2011 | 12:51 PM
Default Boat Idles Weird?
What cause the engine to idle up and down with in 200 or 300 rpms? While just floating.. any info would be great. Thanks mike
rollnhrd is offline
Old 07-11-2011 | 02:25 PM
Blowers?
Ntrsspray is offline
Old 07-11-2011 | 02:53 PM
most likely a vacuum leak...
MikeyFIN is offline
Old 07-11-2011 | 03:13 PM
anewway's Avatar
Possible Idle Air Control (IAC) valve defective
anewway is offline
Old 07-11-2011 | 03:29 PM
If we just knew what engine.... Carb or injection...IAC's are PITA's sometimes.. so are vacuum leaks... if a carbed engine the leak can be in the carb too... a real PITA to find out.
MikeyFIN is offline
Old 07-11-2011 | 06:19 PM
rw40426's Avatar
Mine did that when I had a jacked up map sensor on it. 525
rw40426 is offline
Old 07-11-2011 | 09:54 PM
its a 525 blower with 2 800s on it
rollnhrd is offline
Old 07-11-2011 | 11:21 PM
Default Fixx
its called blower surge,,normal if you have alot of boost
FIXX is offline
Old 07-11-2011 | 11:35 PM
Expensive Date's Avatar
Yup and it sounds cool leave it alone.
Expensive Date is offline
Old 07-12-2011 | 01:27 AM
The surge is caused by each revolution of the blower. Sometimes it can be reduced or eliminated with carb air bleed adjustments.
Griff is offline
