ZT 260 - cuddy storage
Checkmate ZT 260 owners: Do you guys have any access hatches in your cuddy to storage areas either under the bench seats or under the V-berth sleeping cushion? I heard that some boats might have storage areas. Mine does not. I want to cut some holes and put in access hatch covers. But I want make sure that those areas are not filled with floatation foam or something. If so, does anybody have pictures so I can see where they are?
Thanks guys.
Thanks guys.
I called checkmate years back and asked about this, i asked why they dont do it from the facotory and they said the less holes the stronger the boat will be. less stress cracks etc. so i took there word for it, ive had the boat for 4 seasons, its an 03 with over 400 hours and sure enough i have not one stress crack on the boat, and i have used it in the ocean for the 4 season i own it with good size waves etc. boat is solid. so i left it alone.
one easy way might be to cut a small round hole to look inside, go bigger and bigger but go the size of the round inspection hatch incase you find something. then you have an easy patch job.
