Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
how to remove bow roller marks >
Old 07-14-2011 | 09:58 AM
Default how to remove bow roller marks
Last weekend we had to use a very steep ramp since the water was so high. What happened was the boat rolled on the bow roller leaving rollermarks. How can I remove that rubber off the boat? Tryed wd40 already..
stlliberator is offline
Old 07-14-2011 | 10:13 AM
The Magic Eraser ! Works good. Wet with water and scrub a little. won't hurt gelcoat
H2xed is offline
Old 07-14-2011 | 10:19 AM
x2
mookster is offline
Old 07-14-2011 | 12:56 PM
Will wipe right of with a little acetone also. It will strip the wax so you'll need to reapply wax where you cleaned it.
Brandon is offline
Old 07-14-2011 | 08:54 PM
Its thick. Its not just scuffs
Old 07-14-2011 | 10:10 PM
Lot's of magic erasers and patience if it's thick.
Powerquest230 is offline
Old 07-15-2011 | 12:25 PM
Definately acetone with an immediate rewax.
gare is offline
Old 07-15-2011 | 04:24 PM
That's what I did.
Interceptor is offline
Old 07-15-2011 | 04:57 PM
Sydwayz's Avatar
Forum Regulator
See if you can find some plastic razor blades. They are great for such. They are very hard to find though. I found them last at Boat Owners Warehouse in FL. You could try a plastic putty knife too! Just be careful.
Sydwayz is offline
Old 07-15-2011 | 08:10 PM
we use simple green at our shop plus a terry cloth rag,also if you go buy the little white, booty socks for tennis shoes they will pull over the rollers and stop the black marks.
proboat-wes is offline
