Shift into forward 5-10 delay when hot Bravo 1 drive >
Old 07-19-2011 | 02:24 PM
Question Shift into forward 5-10 delay when hot Bravo 1 drive
When cold, works perfect, when hot, reverse perfect. FOrward....wait 5-10 seconds and goes in. If I rev it up just a bit, clunks into gear. (not sure how the RPM has an effect on it)
Just started this weekend, so have not had a chance to adjust the cables. (and don't want to before I hear some suggestions, in case the adjustment is fine)
2Slow4me is offline
Old 07-19-2011 | 03:35 PM
Quinlan's Avatar
Cone clutch is going.
Quinlan is offline
Old 07-19-2011 | 04:58 PM
Maybe low on fluid or fluid needs changed.
Sam007 is offline
Old 07-19-2011 | 06:34 PM
X2
Griff is offline
Old 07-19-2011 | 08:45 PM
Mr Gadgets's Avatar
Charter Member #601
Check your linkage adjustments.. Make sure it is centered.
Dick
Mr Gadgets is offline
Old 07-20-2011 | 12:50 PM
Mine was doing the same thing last year! ( bravo ll ) here to find out i put penzoil 90 wt because west marine was out of mercruiser hp green oil and after a couple of months was doing what yours is doing. Took the outdrive apart and took the cone clutch asm up to the mast merc mechanic and said put it back together and put the mercruiser hp oil in it and your good to go! ( right ) well he was right and its been fine ever since! just my 2 cents
little d is offline
Old 07-22-2011 | 08:23 AM
same situation last year......changed cone clutch and all fixed.....but the guys in my marina did mention that the merc oil has some sort of additive that does help shifting.......I use Royal Purple and they both shift fine.......
Here's Johnny is offline
Old 11-02-2015 | 09:20 AM
Mine is doing same now. What resolved this for you?
tf2ttt is offline
Old 11-02-2015 | 02:31 PM
GeeterB's Avatar
I have had a similar problem, when cold, shifts just fine, when warm, will not shift into forward unless rpm's are way down...anything over 800rpms and won't go into forward?
GeeterB is offline
Old 11-02-2015 | 03:30 PM
On my scarab I put synthetic fluid(sierra) in the drives, one had a delayed shift. Changed to traditional fluid and problem went away.
indysupra is offline
