Jetting with innercooler >
Old 07-20-2011 | 10:33 AM
Default Jetting with innercooler
Hey guys i am going to be adding a innercooler, it is a 1071 blower. Does this change the jetting big time or not? The water will come from the nose cone so when i am not moving it will not see any cold water. One other thing dont think i have room under hood scoop. Do they make taller scoops or just take scoop off? OR???
Thank you for your help!!
skydog is offline
Old 07-20-2011 | 11:00 AM
Depends on what kind of scoop you have now. The water from nosecone is good, you dont want anywater at idle. Be sure to put a PSI relief valve on the chiller, you don't want too much psi in it. As for the Jetting, I can't say for sure. If you are upping the boost, you may need to step it up.
MILD THUNDER is offline
Old 07-20-2011 | 12:39 PM
Thank you very much i am at 10PSI right now with no chiller. So i dont think i will go up any. So same boost jetting can be close?
skydog is offline
Old 07-21-2011 | 01:39 AM
A cooler intake charge puts more air molecules into the mix. It will lean out some. Your boost pressures may actually go down 1-2 pounds as well
Griff is offline
Old 07-21-2011 | 08:15 AM
You think at idle much will change? Idle air mix screw and pump shot?
Thank you Skydog
skydog is offline
Old 07-21-2011 | 11:59 AM
Idle should not be affected. Might just need some small idle air bleed adjustments.
You will probably have to richen up the jetting a couple sizes, but that depends on how rich it is set up now. If its on the rich side now, you could be fine without any changes.
Griff is offline
Old 07-21-2011 | 01:31 PM
Thank you for all your help guys! I am running 10PSI u think it would be a very smart idea to add one?
skydog is offline
Old 07-21-2011 | 02:39 PM
At 10 psi, I would definately add one. If hatch clearance is an issue, you may want to consider a Whipple innercooler. They only add about an inch, but cost quite a bit more.
Griff is offline
Old 07-21-2011 | 03:42 PM
10 4 buddy i will for sure then! The scoop is a problem, i will look at the whipple cooler!
THANK YOU !!!!!!!!! P.S. Motor getting torn down right now i think it might be some DETO....But not bad.. i hope... wrist pin??...... power good ...oil psi... valve train all good has alittle clater at idle... Will know real soon.
skydog is offline
Old 07-21-2011 | 03:51 PM
Default Fixx
What mild thunder was refering to..
when you install a inter cooler you have to plump water through it,,you ill want to install low watrer picp ups on the back of the boat to feed the coolers..at the same time you dont want water going through the coolers at adle on efi engines which will make the injectors puddle and you will have a rich condition, also you will need to install a pressure relief valve so you dont blow the inter coolers with too much water pressure,skipping waver will blow the coolers without a pressure reliev valve..15 psi is a safe number for the coolers..
i see your in ill,,contact VFN fiberglass in addison for taller scoops ,if their too tall you may have to go arizona style and leave them off..
FIXX is offline
