Rim size on myco trailer
Got a tandem axle trailer with Mickey thompson rims. Missing the fourth rim. I know there 16" rims. Bolt circle is 8-6.5 and the tire that was on it is st235/80r16. It's a classic II rim. Would that be a 8" wide rim or 10"?
Also, I think www.championtrailerparts.com sells the same rims. (...the older spoked rims that Myco use to use. Myco has since switched.)
Myco will sell you the rim direct. Then you can source a tire locally.
