Hardin Marine stainless steel sea pump with the cross over >
Old 07-27-2011 | 07:38 AM
Default Hardin Marine stainless steel sea pump with the cross over
Has Anyone used Hardin Marine stainless steel sea pump with A cross over and experienced any problems like low volumes at low rpm? Causing the guage to shoot up after shuting down and go to idle.
rssteiny is offline
Old 07-27-2011 | 08:28 PM
Better take a look at that impeller to see if is all in 1 piece still
firehawkcat is offline
Old 07-27-2011 | 09:27 PM
I have there setup on my 572. And my temp will hang around the 150 area under a load with 140 t stat. But I do see 170 to 180 at idle after a hard run. I just idle it up to 1500 rpms and it seams to cool back down fast. This only happends after a hard run, and then you go right to idle. I belive that mine stays under 160 on the hard runs. Just seams to get alittle hot when you go from hard run, to idle. Just give it a few more rpm's for 30 sec or so and it should cool right back down. At least mine does????
I DIG IT !! is offline
Old 07-27-2011 | 09:29 PM
Yea, low water flow, lots of steam, will not prime, ect.... Last time this came up it was banned and deleted. I had one, they gave me a full refund, exchaged for the old style stock merc body and hardin backplate. I am just telling my experence and not trying to bash them or there products. I know of other here that had the same problem.
jeffswav is offline
Old 07-28-2011 | 08:51 AM
I have a hand ported Merc pump with a Stainless Marine crossover setup. I run 150 most of the time, but it will go up to 180 after a hard run at idle. It cools down after a minute or two.
ThisIsLivin is offline
Old 07-29-2011 | 06:00 AM
must be political.....
ezstriper is offline
