6.0 Headgasket kit and stud kit
I am trying to find for a 05 6.0 headgasket and stud kit. The 18mm dowells. But everywhere i call is backordered. Anyone have a line on some? I would really appreciate it so my friend will get his truck back and i can get my truck back before he tears it up some more.
The stud kit should be the same for all 6.0s the 18mm dowel ran through 06 or 07 but its just the dowel. the bolts/ studs are the same. then they go to 20mm dowels that are found in the later engines or with service oversize heads. I have hundreds of dowels 18mm 20mm and the step 18mm to 20mm when putting a new head on a older engine.
Studs are upgrade. I bought mine off of eBay ARP studs I think. Not sure if I have the name correct, but once I put them on, and did away with the eve while the engine was torn apart, I couldn't kill the 6.0.
I traded it for a 2011 6.7. No comparison, the 6.7 stock pulls better than the 6.0 chipped with propane. New truck is awesome
