trim motor help? >
trim motor help?
trim motor help?
Old 07-31-2011 | 08:16 AM
Default trim motor help?
My trim is stuck all the way in and when I hit the button I can hear it clicking but the motor does not work do I need a new motor or is there something else.
pokey27 is offline
Old 07-31-2011 | 08:22 AM
Go from the battery to purple or blue wire see if it goes up&down?use decent guage wire when jumping it out good luck selenoid or bad connection maybe?
PARADISE ISLAND is offline
Old 07-31-2011 | 08:41 AM
Ok that worked got it to raise so its the seleniod then right but aren't there two of them and both go bad at the same time
pokey27 is offline
Old 07-31-2011 | 09:25 AM
These are the selenoids right
pokey27 is offline
Old 07-31-2011 | 09:50 AM
There are two solenoids but they don't both always go bad at the same time but since they are cheap I always change all of them, Trim pumps and Drives as well. Get them at
http://www.dbelectrical.com/p-3308-n...8-smr6001.aspx
$8 each
Slow Poke is offline
Old 08-01-2011 | 12:19 PM
probably a bad fuse, I had the same problem with mine last year. it would work when I jumped it too. I had to replace an inline fuse since the boat was a 1991 with no reset. hope that helps.
HHHMR is offline
Old 08-01-2011 | 12:27 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It's 3 extra nuts to R&R the 2nd solenoid. I recommend replacing the 2nd one as well.
Sydwayz is offline
Old 08-01-2011 | 06:26 PM
Right on guys thanks got them ordered hope it works.
pokey27 is offline
Old 08-02-2011 | 04:23 PM
I may be a tad late here, but I went through the same thing with mine (38 Fever). My mechanics jumped in there, told me to "exercise the trim pumps"- i.e., work the switch up down, etc. in rapid succession ... and they now work like champs. Ozone is apparently the culprit- building up o the solenoids, then they sit over time and cannot make the circuit
HOWEVER ... never can beat new!
SeaWeasel is offline
Old 08-03-2011 | 12:45 PM
Wally's Avatar
Were doomed!
you can get the solenoids from Napa. their part number is
18-5817
-Wally
Wally is offline
