-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   trim motor help? (https://www.offshoreonly.com/forums/fountain/259211-trim-motor-help.html)
pokey27 07-31-2011 08:16 AM
trim motor help?
My trim is stuck all the way in and when I hit the button I can hear it clicking but the motor does not work do I need a new motor or is there something else.
PARADISE ISLAND 07-31-2011 08:22 AM
Go from the battery to purple or blue wire see if it goes up&down?use decent guage wire when jumping it out good luck selenoid or bad connection maybe?
pokey27 07-31-2011 08:41 AM
Ok that worked got it to raise so its the seleniod then right but aren't there two of them and both go bad at the same time
pokey27 07-31-2011 09:25 AM
1 Attachment(s)
These are the selenoids right
Slow Poke 07-31-2011 09:50 AM
There are two solenoids but they don't both always go bad at the same time but since they are cheap I always change all of them, Trim pumps and Drives as well. Get them at
http://www.dbelectrical.com/p-3308-n...8-smr6001.aspx
$8 each
HHHMR 08-01-2011 12:19 PM
probably a bad fuse, I had the same problem with mine last year. it would work when I jumped it too. I had to replace an inline fuse since the boat was a 1991 with no reset. hope that helps.
Sydwayz 08-01-2011 12:27 PM
It's 3 extra nuts to R&R the 2nd solenoid. I recommend replacing the 2nd one as well.
pokey27 08-01-2011 06:26 PM
Right on guys thanks got them ordered hope it works.:drink:
SeaWeasel 08-02-2011 04:23 PM
I may be a tad late here, but I went through the same thing with mine (38 Fever). My mechanics jumped in there, told me to "exercise the trim pumps"- i.e., work the switch up down, etc. in rapid succession ... and they now work like champs. Ozone is apparently the culprit- building up o the solenoids, then they sit over time and cannot make the circuit
HOWEVER ... never can beat new!
Wally 08-03-2011 12:45 PM
you can get the solenoids from Napa. their part number is
18-5817
