Kaama s/d Prop question
Old 06-05-2002 | 03:51 PM
X-Rated30's Avatar
Default Kaama s/d Prop question
O.K.: The project is getting near completion. Gremlins are leaving the boat like lemmings toward the cliff.
Then comes last night... Tooling along @ 70-75 checking fuel pressure, listening for problems, etc. Then a blade breaks off the stbd prop. Nearly shook us out of the water.
No bent shafts, but now I have a 4 blade prop and a "new" 3 blade one. Drives are Kaama surface drives.
Poll :
1) Am I screwed? What would you suggest?
2) Anybody know what kind of prop will fit these drives?
X-Rated30 is offline
Old 06-05-2002 | 03:54 PM
Katdrvr's Avatar
When I had Kaamas, I used props for a small shaft Speedy #3 or 4. They are not cheap but they are out there. What size do you need. You may have to buy a pair of props.
mike
Katdrvr is offline
Old 06-05-2002 | 05:16 PM
X-Rated30's Avatar
Anyone know where to find them or a price???
Old 06-05-2002 | 06:50 PM
Mbam's Avatar
Offshoreonly Advertiser
What size do you need? We have a pretty good selection of Mercury style props.
Mbam is offline
Old 06-06-2002 | 09:41 AM
MOst Kaama's used a 19 spline .That is standard small shaft speed master size like Katdrvr said . Look in the classifieds hear there are usualy some around .Check to see if you have short shaft or long . Short hub props are about a 3" long hub . I assume if you have 4 blades they are probably long shafts and hubs .(long is better ) Messure it and double check what your buying ! I assume you are about a 24"-26" pitch . YOu should find some . I have seen them for around $500 but most are closer to 1000. If you have trouble finding them ,e-mail me . I will track down a guy in canada that used to have a lot of them . Good luck , JOE
e-mail : [email protected]
boot is offline
Old 06-07-2002 | 01:39 AM
shifter's Avatar
www.weismann.net
You might try Archer Marine (949) 646-9778. Dan or Gary will be able to help. They might have a prop on the shelf to match the one you have. That is Betty Cook's shop (Kaama).
good luck,
pat W
shifter is offline
boatinbabe04
8
07-08-2006 06:58 PM
mopower
02-03-2005 10:10 PM
alj
9
10-13-2004 04:03 PM
jaf302
4
05-19-2003 03:25 PM
