best water pick up for cat stepped hull >
Old 08-03-2011 | 06:42 PM
Default best water pick up for cat stepped hull
Hey guys any pics of water pickups on bottom or back of cat stepped hull? I think mine on the back is getting a lot of air and water. Just would like to see and here what is working on 120+mph stepped cat with a big blower motor.
Thank u guys!!!
skydog is offline
Old 08-03-2011 | 08:21 PM
Airpacker's Avatar
I used the Teague adjustable thru hull. I mounted it behind the sponson thru the notch. Had to do a little glass work inside the sponson to give the flange a mountng surface but it wroked out sweet.
Airpacker is offline
Old 08-03-2011 | 08:29 PM
Nice any pics?
Thank u
skydog is offline
Old 08-04-2011 | 12:03 AM
+ 1
B BOATER is offline
Old 08-04-2011 | 07:55 AM
Airpacker's Avatar
Originally Posted by skydog
Nice any pics?
Thank u
phone pics but that should give you the idea.
Attached Thumbnails best water pick up for cat stepped hull-img_0330%5B1%5D.jpg   best water pick up for cat stepped hull-img_0329%5B1%5D.jpg
Old 08-04-2011 | 10:32 PM
Nice to be adjustable so you can change water pressure on the big end. Rather than our old school way of just slowly cutting it down. Don't want much in the water it will actually take mph way just want perfect pressure depending on if its for the blower or motor.
There is a different version than that one in the picture might look at both see which will work for you hull better
B BOATER is offline
Old 08-04-2011 | 10:55 PM
Strip Poker 388's Avatar
Rob
Teague has the best one out there
Strip Poker 388 is offline
Old 08-05-2011 | 12:27 AM
I think there is one made specifically for Eliminator. I cannot remember who makes it right now, but I read about it in the New Products section of powerboat a few months ago. I was going to retrofit it onto my Profile 28 cat
JRider is offline
Old 08-05-2011 | 04:10 PM
Rob
if ya can cut the bottom to releive it,channel
Attached Thumbnails best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-021-large-.jpg   best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-034-large-.jpg   best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-037-large-.jpg
best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-068-large-.jpg   best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-071-large-.jpg
Old 08-05-2011 | 04:15 PM
Rob
more
Attached Thumbnails best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-060-large-.jpg   best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-090-large-.jpg   best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-117-large-.jpg
best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-400-large-.jpg   best water pick up for cat stepped hull-emerald-beach-pokerun-8-15-09-406-large-.jpg
