Rebuild kit for 9780s carburator. >
Old 08-05-2011 | 08:51 AM
Default Rebuild kit for 9780s carburator.
Just wondering if someone knows a number for a rebuild kit that will work for this carb that I can buy in a auto parts store. It is a weber <---(i think no name at least that i found) 9780s carb, it is on a 1997 scarab 22 454
Ufoman420 is offline
Old 08-05-2011 | 11:23 AM
there should ba a metal tag on one of the top screws on carb to identify it. also most kits cover a certain range of carb#s when rebuilding make sure to match the holes on the new gaskets with the old gaskets
doggiedave is offline
Old 08-05-2011 | 04:41 PM
Default Fixx
summit racing,,just get the edelbrock marine carb rebuilding kit,,all the parts are the same..
FIXX is offline
Old 08-06-2011 | 08:44 AM
I did there wasn't a metal tag on this carb
Cool thanks I really appreciate that, it beats 120 bucks for a few gaskets and jets.
Old 08-06-2011 | 08:50 AM
One more question should i just buy a re-manufactured edelbrock 1410 750cfm for $239 or is the carb I got on it now just as good with a good rebuild.
For the rebuild on mine is this the right one to buy
http://www.summitracing.com/parts/EDL-1477/?rtype=10
Old 08-06-2011 | 12:07 PM
Default Fixx
i would just rebuild what you have,,who knows what merc did to them to get them to run on your engine..If it seems like your boat has no upper rpm power then its probably the screens that go into the needle and seats,,they get pluged up with sediment from the fuel..
FIXX is offline
Old 08-06-2011 | 03:49 PM
Well the problem I'm having after my last trip out the carb is flooding. If I let it idle for 10 min to warm up then take off it dies out then its hard to start then when I get it cleared out a big amour of black smoke comes out. I changed plugs, plug wires, rotor, cleaned cap, and added a second strike ignition box to help with higher rpm spark. I have a good felling the carb is just not mixing enough air with the fuel. I'm lacking take off power and when cruising at 3000 rpm it sounds like 2 cylinders quit working untill I open it up again it goes away.
Old 08-08-2011 | 08:01 AM
Is the rebuild kit I posted the link for the right one?
Old 08-08-2011 | 04:35 PM
Default Fixx
dont know 750 cfm carb kit is what you need. i think their kit does both 650 and 750
from look at the part brake down it looks the same as the internal parts of the webber..
FIXX is offline
Old 08-08-2011 | 11:05 PM
thanks, i called a carb shop, their kit has everything in there for most of the carb's it should be good thanks.
