Anchor for 29 Fever >
Anchor for 29 Fever
Anchor for 29 Fever
Old 08-05-2011 | 09:04 AM
Default Anchor for 29 Fever
I have searched the threads...
What is everyone using for their 29 Fever's with the anchor locker? I want something that will fit securely in the locker and not bang around.
Any suggestions.
lslavick is offline
Old 08-05-2011 | 09:35 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
The 29 I had did not have a locker. On all my Bajas I have always lined the lockers with thick, slushy style floor mats to help limit any banging around. In my experience the anchors rarely stay put. I also use a vinyl coated Navy style anchor that doesn't have any sharp edges. Their ratings are bad (and not accurate). A 20lb holds my 342 in Ohio River current just fine. All depends on where you boat and what you're trying to hook up to.
Baja_342 is offline
Old 08-05-2011 | 09:42 AM
NWPC's Avatar
A Box Anchor and tie it down.
NWPC is offline
Old 08-05-2011 | 12:03 PM
I have a 20lbs navy anchor that seems to do the job
soldier4402 is offline
Old 08-05-2011 | 12:46 PM
If Pickwick Lake has a sandy bottom...Get a Hooker! Put about 6' of chain between it and the anchor line...excellent for soft/sandy bottoms.
Thunderstruck27 is offline
Old 08-05-2011 | 12:52 PM
you have an anchor locker?.....nice
pullmytrigger is offline
Old 08-05-2011 | 08:29 PM
I like the idea of the floor mats, not sure why I have never thought of this on any of my various boats
rexcramer1 is offline
Old 08-05-2011 | 10:17 PM
Thats what I use.. two front floormats for a truck/SUV for the anchor to sit on. Helps limit the banging around.
breakitout is offline
Old 08-06-2011 | 04:36 AM
I bought two of the bolt together "Fortress" aluminum anchors for my 24' Sonic. One I keep assembled (w/chain and line) under a V-berth cushion in the cuddy (so I don't have to crawl across the V berth to get to the locker), the other I switched the anchors lock nuts to wing nuts and keep it disassembled in the aft sun lounge. Easily assembled for a 2nd anchor on the beach.
Twin O/B Sonic is offline
Old 10-03-2011 | 08:08 PM
My 29' is being delivered on the 8th. I'm not sure if it has an anchor or not (I should have looked). If it does I will measure, weigh, and photograph. If not I will share my "adventure" in purchasing something that fits and whatever mods that were necessary. Stay tuned...
Wes Burmark is offline
