14" or 15" wheels
Old 08-05-2011 | 04:09 PM
Default 14" or 15" wheels
What are advantages/disadvantages of one or the other? I assume bigger would be better?
SunsationLarry is offline
Old 08-05-2011 | 04:24 PM
depends on how much you gonna travel with the boat.....if it stays local you can get away with smaller...
MrSneakAttack is offline
Old 08-06-2011 | 05:02 AM
You can get far more weight capacity w/15's than 14's.
Standard/good 14" trailer tires will be weight capacity "C" which if I recall is approx. 1660 lbs.
Assuming tandem axle you will have a weight capacity of 6640 lbs. which sounds like a fair until you back out the weight of the trailer. which is gonna be 1500ish probably.
I couldn't figure out why I kept going through tires on the trailer under my old 24' Sonic until I pulled it across a set of scales and just about died! It was over that weight unloaded!
15' tires would have cured it.
If you do much towing (like I do), don't skimp on the trailer. I should start a thread of the crap I see down here! Some of it under brand new, high dollar rigs.
Twin O/B Sonic is offline
Old 08-06-2011 | 02:06 PM
15" gives a much larger weight range, as stated. Go with the largest load capacity tire that you can, it is peace of mind. 14" limits you to 1760lbs a tire, 15" can give you another 500lbs or so depending on the tire.
Philm is offline
Old 08-06-2011 | 02:28 PM
fireboatpilot's Avatar
RIPSTA Racing Team
And they haven't even started telling you about how much faster that smaller diameter tire is spinning at 65mph and how hot your wheel bearings are getting.
fireboatpilot is offline
Old 08-06-2011 | 04:41 PM
That was a thought that popped into my head yesterday when I saw a jetski being pulled down the highway.
Old 08-09-2011 | 10:23 AM
why use either one of those ? go 16 inch
tim brown is offline
Old 08-09-2011 | 12:42 PM
I'm in the market for a new trailer and I will not settle for anything else, seen too many peoples weekends or worse ruined by blown tires or burnt up bearings.
Doug Doty is offline
Old 08-09-2011 | 12:45 PM
That's what is on my Myco, same size as the truck pulling it.
Wildman_grafix is offline
Old 08-09-2011 | 11:23 PM
I was only told about 14 or 15 from Chip at Phoenix, I will ask tomorrow if 16" is an option. Has a mag wheel option but doesnt say what size.
