strong adhesive/epoxy
Old 08-14-2011 | 02:04 PM
Default strong adhesive/epoxy
need a good strong but liquid adhesive/epoxy thanks Rob
ezstriper is offline
Old 08-14-2011 | 02:17 PM
These are what I use:
Two part epoxy-different set times and rigid
Gorilla Glue- caution of excess glue expanding when drying
Liquid nail-rigid wood connections
3m 5200- the marine standard
pitts1313 is offline
Old 08-14-2011 | 02:21 PM
used 5200 on this before, but did not flow down far enough and failed after a while...so needs to be pretty liquid
Old 08-14-2011 | 02:45 PM
There is a huge fiberglass place local to my in the Tampa Bay area, called Fiberglass Coatings. http://www.fgci.com/
They are super helpful and knowledgeable, i would just call them and explain application. I am sure they will sell whatever you need and maybe you can get it locally if you don't want to ship it.
happy hours is offline
Old 08-14-2011 | 08:36 PM
If you are looking for a two part epoxy look at MAS Epoxies based in NJ.
Hula Boat Care is offline
Old 08-14-2011 | 09:09 PM
glassdave's Avatar
Neno the mind boggler
what are you trying to bond? Remember epoxy requires a roughed up surface for proper mechanical bond. If you just trying to run down into a void the best you can hope for are the fill properties with little actual adheasion.
08 OPA High Points Champion
glassdave is offline
