80 mph goal reached
Old 08-16-2011 | 09:46 AM
Default 80 mph goal reached
Finally reached my goal of 80 mph in my 1995 24' Python. Original motor was a 365 hp 454 Mag and boat would run about 62. Replaced engine with a 540 that I built. Replaced steering with MM full hydraulic. The boat actually ran 83 yesterday and I am really happy with the performance. The boat is a rocket! As most on this sight know, it is a long and painful road to high speed, and I have learned a lot (the hard way).
I want to thank Bob Madera for the cam and the verbal help with my project. He really knows his ship!
Flying Tomato is offline
Old 08-16-2011 | 10:09 AM
How much hp are you running and what type/size prop? How did the boat handle at those speeds? I'm trying to get my 24 Python dialed in and I know I need a different prop but my motor makes about 500 hp. It made 450 hp and 513 tq on the dyno but I changed the heads from stock ported to 320 cc Dart square ports and a Edelbrock intake. 75 mph is more or less my goal but if I can get more out of this combo I want to.
cdail28590 is offline
Old 08-16-2011 | 06:18 PM
Default more info
I have not had the motor dynoed, but it should be around 625 hp. I am turning a 25 Mirage plus, thru a 1.5 at 5650 rpms. The full hyd steering made a HUGE difference in high speed handling and stability. I can let go of the steering wheel and the boat tracks straight--best investment on the boat!
Old 08-16-2011 | 07:57 PM
thats great,python are great boats
innerrage is offline
Old 08-17-2011 | 02:00 PM
Man buddy that is great happy for you!!!! Now go turn and burn!!!!!!
skydog is offline
Old 08-18-2011 | 11:19 AM
according to your numbers ya only have 7% prop slip..thats awsome..how it come out of the hole?
stlliberator is offline
Old 08-18-2011 | 01:20 PM
Congratulations, 80 MPH is a hugh accomplishment. We should start a thread on the Top 10 things that added no speed. I could probably list 20!
BenPerfected is offline
Old 08-18-2011 | 08:26 PM
my goal also....will know this w-end
pqjack is offline
Old 08-19-2011 | 06:35 PM
I cam up with the same figure, sounds like somthing is off.
jeffswav is offline
Old 08-19-2011 | 06:38 PM
Can't go wrong with Bob, he gives great advice. After you talk to him you feel like he is your engine mentor... what a education you get
jeffswav is offline
