procharger experts needed >
Old 08-21-2011 | 08:44 PM
Default procharger experts needed
I found a complete procharger for a grand. Im waiting for the guy to get back to me on what mdel it is. All he knew so far was it was for a carbed 454.
If a person were to run it at 5 psi, how do you figure out the jetting math? Is there a percentage you go up in jets? or????
Right now i have a holley HP marine 830cfm on my 454 pushing around 450hp. I realize ill have to buy a blower carb.
thanks in advance!
zeke is offline
Old 08-21-2011 | 08:50 PM
Hopefully some procharger guys can add more info, but I have heard of problems keeping belts on them.
JRider is offline
Old 08-22-2011 | 12:42 AM
articfriends's Avatar
The belt problems will be the least of his problems with a blow thru carb set-up!! The thing with the belts is really when you try running alot of boost it has to be rubber band tight, at 5-7 psi this is usually a non-issue, Smitty
articfriends is offline
Old 08-22-2011 | 01:47 AM
zeke, you send the carb to The Carb Shop and get it jetted and sealed for a blow thru charger system... thats it. Not something you should do at home unless you want the hassles of it never working properly for you.
If you dont want to send carb out to get it done save the $1000 run your motor the way it is.
kilrbusa is offline
Old 08-22-2011 | 05:51 AM
I run a blow thru carb setups...no issues as of yet..had carb built by prosystems, fuel system critical, need areomotive 1000 pump, #10 line, big filter, aero boost referenced regulator with return to the tank..you will spend more that the 1k to get it all setup correctly, no issues at that boost on belt slippage as long as belt is good and adjusted correctly...you can modify your carb but ???
ezstriper is offline
Old 08-22-2011 | 06:00 PM
mcollinstn's Avatar
If he's got the complete Procharger carb boxes, then he doesn't need to go nuts with the carbs. Just make sure the floats are Nitrophyl (not brass) so they won't try to crush, run a decent boost indexed external pressure regulator, and a high volume high pressure electric fuel pump. Jetting is a little tricky if you don't get the powervalve opening point out of the equation. Some people do away with the powervalves altogether, but I like to tweak them in for cruise. In lieu of tweaking exactly for a specific boat, there is another school of thought to run low (like 2.5HG) powervalves in the primaries (none in secondaries) which allows you to jet a little lighter for cruise.
So easiest method is to start with 2.5HG powervalves in primaries and jet "up" about 12 jet sizes.
Make sure you have a fuel pressure gauge tee'd onto the fuel line to the carbs. Set the external regulator to 6psi and tap the differential port to the carb hat. I assume you will have a boost gauge, and for TUNING you should hook it to the carb hat so you can verify that the regulator is keeping the differential pressure constant (hat pressure = 0, fuel pressure = 6 hat pressure = 5, fuel pressure =11, and so on). After tuning is all done, I prefer to run the boost gauge to the manifold pressure port, but that's later...
So you have good fuel flow at all hat pressures...
You have 2.5 powervalves and really fat main jets.
So go take her for a spin.
If you have a good ear for motors, you can get close with your ears and plug chops. I bet you'll end up 8 sizes fatter than before.
If you have an open plenum intake and large hole carb spacer, you can jet square or staggered. You'll get best cruise economy staggering, but without EGT sensors on all 8, you're safest jetting square.
Have fun.
MC
mcollinstn is offline
Old 08-22-2011 | 09:21 PM
ok got the specs from the guy.
M1 procharger wth msd knock alert, aero fuel pump, belt and intercooler all complete with manuals for a grand.
so i think im gonna grab it its too good of a deal not too..
thanks for the great carb info mcollinstn
zeke is offline
Old 08-23-2011 | 11:42 AM
mcollinstn's Avatar
Carb box?
Regulator?
Make sure the Aeromotive pump has the updated magnet assembly. The older style would grenade the pump when used with fuel containing alcohol (glue holding magnets in would turn loose in the presence of alky, thus turning the pump into a total loss).
MC
Old 08-23-2011 | 01:03 PM
If you don't take it, I will! Procharger's headquarters is about a mile from my house! And I allready have a full Aeromitive(2 miles) setup. Talk about cheap power! But I would send the unit to Procharger and have them go through it. Inspection and or rebuild fee is allways less than a new head unit, and or motor.
Waveform is offline
Old 08-23-2011 | 06:26 PM
Minor rebuild (seals and bearings) at procharger is still expensive, major rebuild on mine was 2000$, a new head unit was 4500$, I would just run it unless it sounds like it has gravel in it, Smitty
