Go Back  Offshoreonly.com > Owners Forum > Powerquest
best way to get a great sound outa 454 mage? ??? >
Old 08-24-2011 | 07:54 AM
Default best way to get a great sound outa 454 mage? ???
K so i got a 454 mag that sounds ok. But i want louder. What the best way for that with out spendi g 1000s of bucks
dra200832 is offline
Old 08-24-2011 | 10:17 AM
Knot 4 Me's Avatar
Assuming your current exhaust tips have baffles in them, replace them with a set of straight-thru tips. The next step would be to replace the stock cast-iorn manifolds with a set of aftermarket manifolds such as Stainless Marine. Better yet, add a set of Lightning or CMI E-Top headers.
Knot 4 Me is offline
Old 08-24-2011 | 12:41 PM
Unless someone changed them to something else I put slash cut Corsa tips on the boat when I bought it. It did have the tips with baffles and was too quiet.
diggin H20 is offline
Old 08-24-2011 | 12:52 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Not gona get much for 1k unless you can find some decent dry pipes used.. New BBC stuff is exp.. Remove any baffles like said.. Exhaust is the only thing that is going to make it louder, unless you change cams, up compression, get the HP sound..
John jr
Fenderjack is offline
