Jetting & stroking >
Jetting & stroking
Jetting & stroking
Old 08-24-2011 | 12:43 PM
Default Jetting & stroking
All the recent jetting talk has me rethinking my jetting. I had the guy who did my heads set up my carb while he was dynoing one of his 505 stroker motors. I’ve found longer stroke motors use smaller jets in 2 stroke sled motors I’ve played with. More pull/ vacuum on the jets w/ longer strokes. Does the same generality hold true w/ the four strokes? Maybe I should fatten up the jetting on my 4” stroke 454 vs the 4.25” stroke 505 the carb was set for. I know plug reads or a wideband will tell me for sure but just wondering what others have experienced.
Itsallgood995 is offline
Old 08-24-2011 | 09:31 PM
SB
Yes, More air thru a carb's boosters pulls more fuel...however, this does not always/usually mean richer Air fuel ratios. Chances are you'll need to add larger jets when adding cids and more power. Edit in: many other things will effect jetting too. Exhaust, cam, intake manifold, etc,etc.
Famous quote from Darrin Morgan - let the engine tell you what it wants. Are you listening ?
In other words, don't guess. Give it what it wants. It will tell you.
SB is offline
