Water pressure >
Water pressure
Water pressure
Old 06-07-2002 | 09:34 PM
2fast4u
Question Water pressure
I have a boat with two 502/500 hp efi motors > What is the min. water pressure at 5000 rpm's to keep these motors cool? Also what is the max. water pressure you can run? I have rased the X diminsion and seem to have low water pressure now, even with low water bravo water pickup on housing. 38 fountain twin step. Thanks for the reply!
Old 06-07-2002 | 11:48 PM
SteveDavid's Avatar
Charter Member #1093
David,
You need to fry those engines so we can finally get around you
But then we wouldn't have that rabbit to chase...... As long as you've got 12 pounds of pressure you'll be fine, with an optimum of 15 up to 20. Anything over 20 pounds and you start risking gasket failures.
On my pleasure boat I'm running 15 pounds at 5400 on supercharged 500 efi's and haven't had any cooling problems. The raw water pump also feeds the intercoolers and there is still plenty of waterflow in this configuration.
In the GMC boat we're running app. 15 pounds.
Best to you, Roger, Tommy and the crew, look forward to seeing you all in Marathon.
Steve
SteveDavid is offline
LostinBoston
18
03-26-2006 07:23 AM
BOATMAN302
3
02-28-2006 08:17 PM
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
merlin540
08-28-2002 05:45 PM
