boat will not plane
Ok guys looking for some ideas, changed oil took boat out ran fine put it on the trailer sat for a week put it back in would not stay running backfired a few times when trying to start. found out pickup coil was bad replaced that put it back in the water would only run 4000 rpm and 45mph vs it's old 5200@80mph.
so i changed the plugs cap rotor and wires. put it in the water will rev fine in out of gear but will not get on plane at all in gear it has a 550 stroker motor in it not very old any ideas all cyclinders have 180 psi
I have not checked that I tried the other day but it is hard to see the marks so I have to mark where 0 is then re adjust I never pulled the distrib so i have no idea how it would jump time i did turn the distrib the other day because but would not idel at all so i was in the water and was doing it by sound and sounded nice and smooth but when i went to take off it was like a turd in a toilet lol
i have never had to set timing before pull the distrib find top dead center on plug 1 reinstall distrib make sure rotor is pointing at #1 or close adjust at a idel and at 3000 rpm, why would it be fine in netruel and not under a load.
