Rev limiter question >
Old 08-30-2011 | 08:41 AM
Default Rev limiter question
Does a rev limiter hurt the engine if you are on it for an extended period? For example, if I'm racing class 6 and don't want to Break-out, is it OK to set the chip, and than run on it for the whole race, 1-hour max.??
Fast Shafts is offline
Old 08-30-2011 | 09:03 AM
SB
1hr ? Don't think anyone has really run on a rev limiter more than a few seconds. Longest would see is a drag car waiting for the tree to go down on a transbrake.
I can't see that being good at all for anything. Torsionally, harmonically, etc,etc..........
And I really don't see that making anything more consistent.
Waste of fuel, engine's VE way down, etc,etc. Remember, your dropping spark events to reduce power.
How about a GPS controlled throttle stop ? LOL.
SB is online now
Old 08-30-2011 | 09:41 AM
I know two current class 6 racers who run against the rev limiter to keep from breaking out. I'm not saying that it's good, only that they are doing it. Some rev limiters will retard timing before it goes to skip spark mode. I hit my rev limiter pretty hard (6k) and I don't hear anything different in the motor, it just stops revving. I have the MSD 6M with the separate rev limiter box with the plug in modules it seems to control rpms very accurately and smoothly. I like the GPS device idea though.
ThisIsLivin is offline
Old 08-30-2011 | 02:08 PM
The problem with retarding timing while under full load like that is that it sends EGT's through the roof. This is fine for a few minutes but for an hour that will probably result in meltdown.
Philm is offline
Old 08-31-2011 | 07:57 AM
Thanks for the responses. Phil, I didn't understand what you meant by "sending EGT's thru the roof"?? Could you please help me to understand? Does the MSD box retard the timing?
For what its worth, I also run an MSD-6 with plug in rev modules.
Thanks again.
Old 08-31-2011 | 08:44 AM
MSD box does not retard the timing. It makes cylinders miss randomly. Retarding the timing makes the Exhaust Gas Temps go extremely high.
picklenjim is offline
Old 08-31-2011 | 09:30 AM
Thanks Pick!
