supercharger efficiency >
Old 08-30-2011 | 09:22 PM
Default supercharger efficiency
Looking into adding a supercharger to a 454 mag carb engine. How much is the sc going to effect fuel mileage at cruising speed and at wot? I don't mind if it sucks it down at wot, but would like to retain some efficiency at cruising speed....
tnc110 is offline
Old 08-30-2011 | 10:11 PM
I find its better milage with the super charge it allows you to run more pitch so your cruse improves
goebel1 is offline
Old 08-30-2011 | 11:19 PM
Default fixx
or you can run a procharger which boost dont come it until 3300 ish rpm's,,will also save your drive..
FIXX is offline
Old 08-31-2011 | 09:08 AM
I put a Procharger on my 454Mag MPI and my fuel economy has actually IMPROVED......except when she goes into boost.....
FogduckerIII is offline
Old 08-31-2011 | 08:34 PM
articfriends's Avatar
I find this to be true too, my boat gets about 3-3.5 mpg cruising w/ blown 540 compared to 2 -2.5 mpg stock 502, Smitty
articfriends is offline
Old 08-31-2011 | 08:46 PM
offthefront's Avatar
Hot Damn !!! Can't wait .... 10 MPG !!!!!!
offthefront is offline
Old 08-31-2011 | 09:46 PM
WOW all sounds good. So...keeping budget in mind...what is the best settup for me.
tnc110 is offline
Old 08-31-2011 | 10:17 PM
No such thing as a budget when it comes to superchargers ! Just add it all up and x by 2 might put you close .
Jeff P31 is offline
Old 09-01-2011 | 09:45 PM
Ouch! So plan on 10k huh? Sounds like buying a Nitrous system...sounds cheap until you add all the things you want/need above the initial kit...
tnc110 is offline
Old 09-02-2011 | 05:04 AM
I am with you there. If you have a top mount charger add in the price of glass work and paint. Oh, and cockpit cover. Oh yeah mooring cover. I spent way more than I had budgeted for my install.
JRider is offline
