adding oil thermostats, what is the simplest install?
Already have a complete setup, so what is the easiest way to ad a thermostat? Looking for the least additional plumbing.
Not sure of your setup, but if you just want to rig an oil thermostat into your existing system, this old picture shows an install that is about as easy as you can get. IMO, it is best to do this project with the engine out of the boat. Remember, an oil thermosat slows/controls the flow oil so generally you will need to upgrade your existing cooler so you can hold the oil temp in the 212-220 degree range....even at extended WOT runs.
The Mercury HP500 style thermostat/filter mount is one of the easiest to plumb and mount, the only drawback is that the fittings are smaller than some of the aftermarket units... IMO.
The Eickert/Hardin unit is a nice piece, but they tend to be a pain in the a$$ to plumb and mount due to their shape:
http://www.cpperformance.com/p-14580...12-degree.aspx
Canton makes a nice piece too, and it's easier to mount and plumb:
https://www.cantonracingproducts.com...ion&key=22-480
The easiest to use would be an oil cooler with the oil thermostat integrated. Dont have to change/add any oil lines. Little more expensive but probably much less of a headache.
http://www.cpperformance.com/p-13666...il-cooler.aspx
Now with that said, I have the Canton and it seems to work very well at keeping the oil temps up, even with no water temps.
