P.Q kplanes
Old 09-06-2011 | 10:53 PM
Default P.Q kplanes
can anyone help me decide which k-planes will be the best for my boat?
290 Enitcer
twin 502's
runs upper 70's - it hase more speed, but its' a little loose at high speeds.
any advice is appreciated
eriknelson is offline
Old 09-07-2011 | 07:03 AM
upper 70s with more left in it??
I take it the engine have had work done to them or thats speedo non GPS speeds..
stick with the 280 Kplanes and add hydraulic steering...290s do like to chine walk at higher speeds..no fix for it..they have a rocker built into the hull right in front of the tabs which adds to the chine walk but helps with porposing..
boatnt is offline
Old 09-07-2011 | 02:51 PM
yes - i bought the boat off of here last winter out of long island. i was told the motors were built by oean offshore, in conneticut?? they run great, very strong sounding! i went through all the external parts to keep it fresh.
Is there any thing in can do to stop the chime walk?
I found a pair of 380 k planes, what you think?
Old 09-07-2011 | 02:54 PM
it is on GPS - and it does have lathym extermal steering. i'm trying to figure out how to post a pic up here lol
Old 09-07-2011 | 07:48 PM
I'd like to see that kinda speed! I'm running stock 502's with only 23p 3 blades, and the best I've seen on GPS is 71. I do see some chime walk if I'm not trimmed just right on the top end, and depending on water conditions I can get it to settle down.
Jplanes is offline
Old 09-07-2011 | 08:45 PM
its on GPS - motors are not stock - i am trimmed up, and tabs down, so i pull out of the gas around 77 ish. It just gets a little squirly...im wondering if i can do some thing to prevent that?
bigger planes??
Old 09-08-2011 | 06:59 AM
bigger planes??
nothing you can do its the boat...
you are doing 77 with the tabs down??you must have the fastest 290 built.
boatnt is offline
Old 09-08-2011 | 07:03 AM
thats sounds about right 71-72 mph on GPS with 502...23 pitch props...
somewhere I have the PowerQuest test results from the mid 90s when I bought my 1st new 290 and it shows 64-66 with 7.4s...66-69 with 454 mags and 70 to 72 with 502mpi..
boatnt is offline
Old 09-08-2011 | 02:24 PM
lol i will have to wait until next season to snap a pic of the gps - i know you dont believe me , but the boat runs that. The motors a built strong! Before i put it away, i will take a pic of the motors, and drives -
It doesnt tell whats inside, but trust me, they are BUILT!
i know you " boatnt" know a ton about PQ - help me out ! lol
Do you think 380 kplanes will help?
Can i have someone work on the bottom of the boat?
Old 09-08-2011 | 03:39 PM
No sorry if I coming off like I dont believe you..I have NO reason not too.Iam serious when I say you must have the fastest PQ 290...Its cool to have a 290 that reaches those speeds..
as far as the chine walking ....Ive owned 3 290s and also have friends that own them and they all sometime chine walk pretty bad...it almost feels like they want to ride on the rub rail...lol...at time you can drive through it at times you cant..
I think one of the main reason is that rocker/shingle thats built into the hull right in front of the trim tabs..at higher speeds it lifts the stern too high and your riding too much on the bottom of the V of the hull..kind like you walking a straight line one foot in front of the other,as soon as you loose your balance you lean from side to side trying to balance again..not sure if you understand what Iam trying to say but that the best I could explain it..
again sorry if I sounded like I didnt believe you...290s are great/strong boats..
I like to think of them as a Lexus and not a Porsche..they may not be the fastest but they get you there in style
boatnt is offline
