Go Back  Offshoreonly.com > Owners Forum > Saber
What are you guys running for props (28's) >
Old 09-07-2011 | 03:35 PM
Default What are you guys running for props (28's)
I have been doing some prop testing, just kind of curious what everyone else is running and how they like what they have. Or if anyone has played around with some different stuff and what the results were.
hotjava66 is offline
Old 09-07-2011 | 07:58 PM
Chris's Avatar
running 30 pitch bravo/4 blades.
i have played with 3 blade vs 4 blades on other boats, not this one but i always thought the 4 blade was a better all around prop... just my .02
Chris is offline
Old 09-07-2011 | 09:10 PM
Still running three blades they blow out all the time, found that to be the case on the single 28's as well. four blades way better.
CHASIN THE DEAL is offline
Old 09-08-2011 | 05:45 PM
I just tested a set of 4 blades, lost almost 5mph top end and they porpise worse than the 3 blades. Much better out of the hole though, snappier mid range. Cruise speed at same RPM was just about equivalent. I think they have less bow lift than the 3 blades, so it takes even more speed to carry the bow while trimmed out without going into porpise mode. Pretty sure I am going to send my 3 blades out for labbing and adding some cup to carry the bow a little better. The 4 blades with labbing to the hull would probably be good all around and a touch slower, but I am not going to spend that kind of money just to try it.
Old 09-11-2011 | 04:34 PM
I'd ask him his opinion about Rev 4's, if they make one large enough for your application.
BGIII is offline
Old 09-12-2011 | 03:02 PM
He said they are worth a try but didnt have a set of test props in the right size.
Old 09-13-2011 | 12:38 PM
I've been running labbed 23 since I got the boat. Of course mine is single, and not much for power. I've been thinking about a 24 for a little more bite.
Saber Steve is offline
Old 09-13-2011 | 07:57 PM
Steve I run a 24 4 blade...never played with anything else on it. Get pretty good results I spent $200 this last winter and had it tuned which did nothing for me but make it look a bit better when it's on the trailer.
cwc5775 is offline
Old 09-15-2011 | 09:17 PM
AIR TIME's Avatar
guys a rev4 by merc works great on deep drives with straight bottoms, call or email Brett at bblades he has a program so you can test props. cwc who did you use, thats not right.
AIR TIME is offline
Old 09-16-2011 | 08:03 PM
Registered User
steve im running a 24 labbed on mine and doing 73 on the limiter we can hook up and give it a try on your boat before you purchase one. cwc you might of had someone work on it that didnt know how to do it right. i had my normal prop guy (for the cheap stuff) check the pitch on a prop, he tweeked it and polished to a mirror finish absolutly beautiful but i lost 6 mph he polished the cup out of it. send it to another place I would recomend bblades or dans prop shop
martins custom marin is offline
