new velocity owner need prop help >
Old 09-15-2011 | 04:23 PM
Default new velocity owner need prop help
i recently purchased a 96 26' velocity. it has a hp500, 557hp, 26p hydro prop, and runs 67mph at 5800rpm. doesn't seem right to me. i'm not sure what prop to try without spending a ton of money. thanks for any help
aboozel is offline
Old 09-15-2011 | 08:18 PM
Velocity Vector's Avatar
Crazy Energy
Call Ron He will tell you want you need. No questions
http://www.hillmarine.com/
Velocity Vector is offline
Old 09-15-2011 | 08:48 PM
ziemer's Avatar
The Hyrdromotives, usually run well on the Velocity's depending on which model it is. I'd recommend talking to Todd at Hydromotive, since that's what you already have. Maybe he can tweak what you have.
Todd: (330) 425-3629
ziemer is offline
Old 09-16-2011 | 09:38 PM
mikes280's Avatar
why not call velocity my bet Steve will know better then anyone, but in the mean time how about a 28 bravo
mikes280 is offline
Old 09-16-2011 | 10:11 PM
Yes i would call Steve.
If you are pushing out 557 hp a 26 hydro is too small. I am using a 26 with a slightly tweaked 502 mag. A 28 bravo will also be too low a pitch as it is equal to a 26 hydro.
Padraig is offline
Old 09-16-2011 | 10:48 PM
I would run a 28 Bravo 1. I am running a 28 Bravo 1 @ 5500 rpms with just a little more hp than your running.
Revd Up is offline
Old 09-17-2011 | 10:35 AM
mikes280's Avatar
bingo
mikes280 is offline
Old 09-17-2011 | 11:00 AM
mikes280's Avatar
also you are a 260 he is what is now a 280
mikes280 is offline
Old 09-17-2011 | 11:38 AM
thanks for all the help. ill try to find a 28p bravo for now and call a few places for there suggestions
aboozel is offline
Old 10-29-2011 | 10:43 AM
Default Props
My 26 has 600hp and I'm running a 30p merc 4 blade runs 80mph at 5200rpm
SPEEDWAD is offline
