Is Power Steering Cooler absolutely necessary? >
Old 09-18-2011 | 11:54 AM
Scarab28's Avatar
Default Is Power Steering Cooler absolutely necessary?
Has anyone run successfuly without a power steering cooler. what happens if you don't run one, will PS fluid overheat? What temps? (running full hydraulic system)
Scarab28 is offline
Old 09-18-2011 | 12:02 PM
seafordguy's Avatar
I don't KNOW on a boat, but I do know that my Father's Jeep Grand Cherokee had a leak and he cut the wrong fitting off by accident - long story short he just bypassed the cooler. It has never made a difference and they just made a 10 hour drive to Hilton Head about a month ago in 100 degree temps.
Not sure that helps at all though.
seafordguy is offline
Old 09-18-2011 | 01:56 PM
Rookie's Avatar
There is a thread on here about it. Something about car runs between 1800-2200rpm, boat 3800-5500rpm. The extra shear heat from rpms is the problem.
Rookie is offline
Old 09-18-2011 | 02:04 PM
Default fixx
yes you need one,the ps fluid will over heat and turn the oil black,it will also cause internal dammage to the internal parts of the pump and if the temps get to high it will blow the seals in the steering rack..
FIXX is offline
Old 09-18-2011 | 02:08 PM
x2
jeffswav is offline
Old 09-18-2011 | 03:37 PM
obnoxus's Avatar
Charter Member #1171
Yup,,,,,just ask my know it all brother in law !!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 09-18-2011 | 04:07 PM
articfriends's Avatar
I bypassed mine a few years ago after going thru three coolers in 7 years due to cracking on cheap merc coolers mounting tabs and have had NO problems with fluid burning or foaming, turn motor as high as 6200 and have twin ram external full hyd steering, Smitty
I posed this same question a few years ago and got the same differing answers.
articfriends is offline
Old 09-18-2011 | 04:10 PM
Yes, you do need one. The higher, sustained rpm combined with the potential of 2000 psi, genertates a TON of heat.
Eddie
Young Performance is offline
