2002 merc 500 efi top end advice >
Old 09-19-2011 | 06:32 PM
Default 2002 merc 500 efi top end advice
I am looking for advice on what to replace ie: springs/ valves or headwork on my 02 merc 500 efi's that have a little over 400 hours on them. Last time out I started hearing some pinging and minor backfire upon takeoff from one motor so i put it back on the trailer. I know that they are common for breaking valve springs so I am looking for advice on what new ones to replace and where the best place to get them. Also if there are any minor upgrades to do while they are apart. Any info is greatly appreciated. thanks, Justin
jus491 is offline
Old 09-19-2011 | 07:40 PM
New springs for sure..Check your fuel pressure on that pinging!!!!
chad1 is offline
Old 09-19-2011 | 09:01 PM
Smitty's Avatar
Replace valve springs and have guides checked for wear and replace where necessary.
Also have the ports cleaned up and make sure to have the injectors flowed and replace any that are out of range.
Smitty is offline
Old 09-19-2011 | 09:48 PM
Sounds like its time to freshen the top end. Jim valeko is really good with heads and works on Ryans 02 black thunder which is now running in the 80's!
any pics of your black thunder?
offshorexcursion is offline
Old 09-20-2011 | 09:43 AM
thanks for the input. does anyone have suggestion for what kind of springs or guides and where to purchase. I will try and post pic later.
jus491 is offline
Old 09-20-2011 | 10:31 AM
Knot 4 Me's Avatar
Head gaskets are most likely gone too.
Knot 4 Me is offline
Old 09-20-2011 | 12:16 PM
+1
JaayTeee is offline
