Formula 419 prop or rpm limiters >
Old 09-20-2011 | 07:57 PM
Question Formula 419 prop or rpm limiters
Hi guys I finished testing my 419 here are the stats.
before procharging.....................5% m1 procharger x 3
502 x 3 mpi................................502 x 3 procharged mpi
5200 rpm= 66 mph.....................5200 rpm= 81 mph
25p mirage.................................28p bravo props X 3
1.5 gear.....................................1.5 gear
The problem is i am still bouncing of my rev limiters. there is 100 hrs on the motors. do i repitch my 28 to 30 and lab them, knowing each pitch is 200 rpm drop.this will increase the load on the bravo drives. But there are 3 of them. or do i change the limiters to 5800 rpm and increase both boost and working rpm on 100 hr motors. thx
born free is offline
Old 09-20-2011 | 11:37 PM
jeff32's Avatar
only 66 mph before procharging?
jeff32 is offline
Old 09-20-2011 | 11:44 PM
Default fixx
go to labbed bravo 30's and raise the rev limiters to 5400 and go boating.
FIXX is offline
Old 09-21-2011 | 06:46 AM
If i put the 25p 4 blade bravos on and opened it up on water with a 2 foot chop I could get a 71 mph on gps. with 2 people aboard. but i lost alot of mid range due to lack of chop on my lake. Most of my boating is on a small lake and river. Its an sr1 non stepped hull so it needs the chop. boat is comfie and well built. In other words heavy !
Old 09-21-2011 | 11:09 AM
Try some stock Bravo 1 30's to get a baseline and go from there.
Griff is offline
