VORTECPRO VS Bob Madera/Haxby >
Old 09-22-2011 | 10:34 PM
Default VORTECPRO VS Bob Madera/Haxby
Called out by Bob Madera/ Haxby to an engine edurance test. Rules: 454 production block, 454 production heads, any thing else goes. Testing procedure: Haxby/Madera will make one HP dyno pull, then run at 6500 RPM for 20 minutes under full load. The water will then be changed and Vortecpro will follow the same test, which ever engine finishes the test will win, if both engines finish the (endurance test) the highest HP will win. Fuel will be 89 octane as speced by Haxby, 10,000 dollars will be held 30 days in advance (prior to the test) by Mike Lewis, winner takes all. The test shall be conducted at Westec in Ca.
Vortecpro is offline
Old 09-22-2011 | 10:38 PM
On a SuperFlow Dyno? Say it aint so.
One more thing-----define "production heads".
ROTAX454 is offline
Old 09-22-2011 | 10:48 PM
LOL - See 330HP - 400HP thread.
Weak!!!!
WETTE VETTE is offline
Old 09-22-2011 | 10:49 PM
Heads that came on a production 454, I think water capacity will be very important.
Old 09-22-2011 | 10:55 PM
Weak!!!!
He's a posser doesn't like the last thread, so he starts an other with the same thing in it? WTF is that?
Zone 5 is offline
Old 09-22-2011 | 11:03 PM
Old 09-22-2011 | 11:11 PM
Weak!! Why not agree to the original terms Bob outlined as everyone will be there? You said you were down with anything, apparently not. (LOL)
Your shop looks nice!
Old 09-22-2011 | 11:20 PM
This guy is a joke! The other tread he said his peanut port 454 would stomp any 454 with aluminum heads. Now the whole program is changing. And he won't go to the venue that Bob has already set up because he's chicken!
For the real story read this: starts on page 3 and goes on and on and on.
http://www.offshoreonly.com/forums/g...hp-400-hp.html
endeavour32 is offline
Old 09-22-2011 | 11:29 PM
This is his MO on multiple sites. when things don't go the way he wants, he tries to misdirect or just posts the same cut/paste over and over. As I said before, he bogus challenge was accepted using the Outerlimits dyno. Then he wanted to change all the rules, and add $10K bets etc etc. Long story short he never showed. Just like he won't here.
http://youtu.be/qZeG-bhe4_w
video of his high tech dyno room.
Zone 5 is offline
Old 09-22-2011 | 11:31 PM
Were did I say that, your a very uninformed, key board commando.
