TRS Trim Anchor Pin Help >
Old 09-24-2011 | 02:23 PM
Default TRS Trim Anchor Pin Help
I am trying to remove the tie bar saddles on my TRS drive because I am going to full hydraulic steering and using the tie bar up high. I can't seem to get the trim ram anchor pins out to save my live. Any ideas?
Scarab9626 is offline
Old 09-24-2011 | 03:38 PM
I assume you soaked them in WD-40. They can be a problem if they haven't been removed in a while. I usually bang them out using a brass drift. Put a nut on the threads do you don't mess them up.
JTeam is offline
Old 09-24-2011 | 03:41 PM
Rookie's Avatar
These?? Maybe put some penetrant (PB Blaster) on them and let them soak over night.
Rookie is offline
Old 09-24-2011 | 04:24 PM
Those would be the ones. I have been letting them soak. I will keep at it.
Old 09-24-2011 | 05:52 PM
Rookie's Avatar
I have also double nutted them and spun them to loosen them and spin them out. Also wood and a hammer, do not hit the threads.
Rookie is offline
Old 09-25-2011 | 12:14 AM
Damnnnn, Look'n good there Rookie!!
picklenjim is offline
