Can you achieve greater speed / horsepower with real gas? >
Old 09-28-2011 | 12:40 PM
Default Can you achieve greater speed / horsepower with real gas?
I am sure this has probably been answered somewhere before. But, if your fuel pump and injectors can only flow X amount of volume at full throttle, will a boat go faster using real gas of the same octane vs. fuel that has ethanol?
Along with all of the other ethanol related documented issues, I have read that real gas has more usable energy per volume than ethanol. So is thinking correct that at max. capable fuel flow that you will get more performance out of your boat with real gas?
Thanks in advance for your help.
SWW17 is offline
Old 09-28-2011 | 01:01 PM
Since the fuel usage with 10% Ethanol is 20% (approx.) higher than with plain gas, I would have to agree with your idea that the power output is lower.
Since the 10% Ethanol gas is not mandated in all States for Marine use, I'll never understand why boat clubs, at least, don't insist on receiving non Ethanol fuel for their members.
Hematite is offline
Old 09-28-2011 | 01:02 PM
t500hps's Avatar
21 and 42 footers
Technically yes, the engine will make more power. If it's 1-2 mph I would be surprised.
t500hps is offline
Old 09-28-2011 | 01:26 PM
Wow, can 20% greater volume of fuel burn for ethanol actually be possible? If so, it would really pay to look high and low for real gas at all costs.
If that approximation was close, it would seem that it would really cut down on performance and fuel range.
SWW17 is offline
Old 09-28-2011 | 01:33 PM
I'm sure some of the skater guys agree!
triple 300s is offline
Old 09-28-2011 | 01:36 PM
THEJOKER's Avatar
I've never run ethanol in my boat. If you travel with your boat plan ahead and I think you can always find non ethanol fuel.
THEJOKER is offline
Old 09-28-2011 | 01:37 PM
Yes I would estimate 20% seems accurate. Last year Allegheny County, PA mandated 10% in marine fuel and efficiency has dropped off a lot.
bmtbandit is offline
Old 09-28-2011 | 01:46 PM
I'm sure other people have this question. Does using a product like Star-Tron or buying gas with a Valvtect additive keep the ethanol from causing problems in boats with fiberglass fuel tanks? I'm looking at a boat that might have a glass tank.
E Colby is offline
Old 09-28-2011 | 02:02 PM
t500hps's Avatar
21 and 42 footers
If you can find non "E" fuel in central VA would you PLEASE let me know where!!!!! I called a local distributor and they don't know of any.
t500hps is offline
Old 09-28-2011 | 02:33 PM
would you rather run 93 octane with ethynol or 89 non ethynol?
Boomer35 is offline
