Battery Boxes
I need two metal battery boxes with lids. Not to be used for bateries but I'm sure they would be perfect. I have weight in the bow(lead shot) and I don't want it to bounce around so I was going to mount a box in each pickle fork and put the lead inside. IDEAS? Otto
Did one job a while back where they did not want the weight to be seen at all in the boat, So I made a simple thick Paste of Resin,cabosil,milled fiber and buckshot Filled the Keel and up the stem knee I shaped it to once again resemble the Hull then glassed over and re finished the area with Interior gel coat. untill this day I do not believe they Know there is 200 pounds of lead in the front of the Boat.
Best Regards
Best Regards
