28 Skater boat lift >
28 Skater boat lift
28 Skater boat lift
Old 10-18-2011 | 01:06 AM
Default 28 Skater boat lift
Anyone have information on hydraulic boat lifts that will for sure fit a 28 Skater? This type of lift, but fit for a 28 Skater... http://www.sunstreamcorp.com/Sunlift.htm
skaterator is offline
Old 10-18-2011 | 10:18 AM
All they do is widen the bunks, raise the front a tad higher than the rear to compensate for the angled tunnel and make the supports taller. Thats about it. Everything else is the exact same.
waterboy222 is offline
Old 10-20-2011 | 02:04 PM
I have mine on a 10 foot wide, 5000# capacity Shore-Station. I just built some bunks like the trailer has and it sits on there perfectly. Dave
Dave Z is offline
Old 10-20-2011 | 02:39 PM
Not sure where you are located but we have a cradle for sale that was utilized for a 32' Skater. It is galvanized which is a ladder style with cross bars to tie the two ladders together.
I can send you a photos if you provide me with an email address.
Thanks,
Fred
Allstar Marine
Cradle is located near Baltimore, Maryland
allstarmarine is offline
Old 10-21-2011 | 10:39 AM
runninragged's Avatar
Default craddle
allstar im interested in craddle call me @ 631-872-0995 thanks jeff
runninragged is offline
Old 04-23-2012 | 09:49 PM
I'm still struggling to find a hydraulic lift that will work with a 28' Skater without a lot of structural modification. I'm still running into the same problem where the beams that hold the bunks are too wide for the tunnel. Anyone out there using a hydraulic lift with your 28'?
Old 02-16-2014 | 10:08 AM
From: East Texas Waterfront- running errands if anyone asks
Just skimming through some old threads and thought I should have some opinions on a proper lift for a 28 or 32 Skater. I use a Boathoist USA cradle for my Scarab but straps would work fine. I'll be sharing this slip sometimes with a Skater or other cat. Can I lift a 28-32 Cat using straps under the sponsons without any problems longterm. TIA.
Flightplan is offline
Old 02-17-2014 | 08:13 PM
My skater came with a hydraulic Naylor lift.
erik1976 is offline
